Qué necesitas
Flip the mouse over to gain access to the bottom.
Using a scalpel, pick, or similar tool, peel away the slide pads on the bottom of the mouse in order to expose the three screws.
Using a PH0 / Phillips #0 driver, remove the 3 screws shown in red.
Gently separate the two halves of the case. Light prying may be required.
For PCB removal : remove 3 PH0 screws from PCB surface. The whole PCB can be taken out for inspection and repair after the screws are removed.
I experienced one switch working intermittently. In such case, I recommend replacing both L & R switches.
This is helpful for finding the correct replacement or compatible replacement e.g. vendors from online store AliExpress.
I used this as a successful replacement: RS Components Stock No. 682-1519 microswitch. Manufacturer is Omron, manufacturer part number is D2F-F.
Una persona más ha completado esta guía.
