Saltar al contenido principal
Logitech M535 Disassembly
Qué necesitas
  1. Logitech M535 Disassembly, Logitech M535: paso 1, imagen 1 de 1
    • This is how the mouse looks like once fixed
  2. Logitech M535 Disassembly, Open the battery box: paso 2, imagen 1 de 1
    • Slide the cover open to get to the battery
  3. Logitech M535 Disassembly: paso 3, imagen 1 de 1
    • Pull the sticker inside of the battery box slowly: the glue is pretty strong and the space is tight. A butter knife works alright. You need to remove enough of the sticker to get to the bottom of the battery box.
  4. Logitech M535 Disassembly: paso 4, imagen 1 de 1
    • The little screw is approximately there (it occurred to me I should write a guide only after I closed the mouse).
    • Gently pull apart the top and the bottom at this stage with some care to avoid breaking the internal plastic.
Conclusión
4 personas más completaron esta guía.
Sam Curti
Miembro Desde 03/19/19
239 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 148
Todo El Tiempo: 2,106
