Introducción
Taking the outer shell off is very easy and all of the internals are visible when it is removed.
Partes
  1. Remove the battery hatch and batteries.
    • Remove the battery hatch and batteries.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the single Phillips screw located between the battery sockets.
    • Remove the single Phillips screw located between the battery sockets.
  4. Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
Conclusión
4 personas más completaron esta guía.
Anna Sweetnam
Miembro Desde 08/04/10
232 Reputación
1 Guía escrita
I got to step 3. where is step 4?
hawaii50 - Contestar
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - Contestar
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 15
Últimos 30 Días: 77
Todo El Tiempo: 3,277
