Introducción
Common causes of a faulty mouse button are frequent use, clicking too hard, and dust getting into the switches. The purpose of this guide is to detail how to replace the switches on your Logitech M100 Mouse with the goal of prolonging the life of your mouse.
This guide does not require specialized knowledge except a basic understanding of a soldering iron. Soldering material is metal with a low melting point. Be cautious of the iron and solder's heat when replacing the mouse clicker, as it very hot and can burn skin. It's also important to work in a well ventilated area as the solder can emit fumes that are not good to breath. For more information about soldering, take a look at the How to Solder and Desolder Connections guide.
Qué necesitas
Disconnect the mouse from any devices before attempting to remove any parts or starting the repair.
Flip your mouse over so the bottom is facing up.
Use a soldering iron to heat the solder points securing both switches, and remove the switches using tweezers.
Congratulations, you have now replaced the clickers on your mouse and can continue using it!
2 personas más completaron esta guía.
