Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Logitech K120 Keycap Removal
Qué necesitas
  1. Logitech K120 Keycap Removal, Removing The Small Keycaps: paso 1, imagen 1 de 2 Logitech K120 Keycap Removal, Removing The Small Keycaps: paso 1, imagen 2 de 2
    • For small keycaps (1st image), the only tool needed is a spudger. Pry the keycap off by wedging a spudger beneath the key and prying up. (Shown in 2nd image)
    • Preferably, use a plastic spudger. A metal spudger may damage the keycap.
    Pregunta a FixBot
    Agregar Comentario
  2. Logitech K120 Keycap Removal, Removing Large Keycaps: paso 2, imagen 1 de 2 Logitech K120 Keycap Removal, Removing Large Keycaps: paso 2, imagen 2 de 2
    • When removing large keycaps (shown in image 1), a metal bracket connects the keycap to the front chassis. (Image 2) Use a spudger to separate the bracket from the keycap.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
The key caps on the Logitech K120 keyboard are very easy to remove, you just need to pry a bit.
7 personas más completaron esta guía.
Camuise
Miembro Desde 11/22/18
1,675 Reputación
7 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 43
Ultimos 30 días: 186
Todo El Tiempo: 16,428
