Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Logitech K120 Keyboard USB Cable Replacement
Qué necesitas
  1. Logitech K120 Keyboard USB Cable Replacement, Removing Screws: paso 1, imagen 1 de 2 Logitech K120 Keyboard USB Cable Replacement, Removing Screws: paso 1, imagen 2 de 2
    • Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise.
    Pregunta a FixBot
    Agregar Comentario
  2. Logitech K120 Keyboard USB Cable Replacement, Separating The Keyboard's Chassis: paso 2, imagen 1 de 3 Logitech K120 Keyboard USB Cable Replacement, Separating The Keyboard's Chassis: paso 2, imagen 2 de 3 Logitech K120 Keyboard USB Cable Replacement, Separating The Keyboard's Chassis: paso 2, imagen 3 de 3
    • Use the spudger to separate the top of keyboard from the bottom of the keyboard.
    Pregunta a FixBot
    Agregar Comentario
  3. Logitech K120 Keyboard USB Cable Replacement, Removing The Top Of The Keyboard: paso 3, imagen 1 de 1
    • Remove the top of the keyboard and put it aside.
    Pregunta a FixBot
    Agregar Comentario
  4. Logitech K120 Keyboard USB Cable Replacement, Removing The Bracket: paso 4, imagen 1 de 3 Logitech K120 Keyboard USB Cable Replacement, Removing The Bracket: paso 4, imagen 2 de 3 Logitech K120 Keyboard USB Cable Replacement, Removing The Bracket: paso 4, imagen 3 de 3
    • Unscrew the highlighted screws using a Phillips #000 Screwdriver. Turn the screwdriver counter-clockwise.
    Pregunta a FixBot
    Agregar Comentario
  5. Logitech K120 Keyboard USB Cable Replacement, Removing The Circuit Board: paso 5, imagen 1 de 3 Logitech K120 Keyboard USB Cable Replacement, Removing The Circuit Board: paso 5, imagen 2 de 3 Logitech K120 Keyboard USB Cable Replacement, Removing The Circuit Board: paso 5, imagen 3 de 3
    • Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures)
    Pregunta a FixBot
    Agregar Comentario
  6. Logitech K120 Keyboard USB Cable Replacement, Removing The Cable: paso 6, imagen 1 de 2 Logitech K120 Keyboard USB Cable Replacement, Removing The Cable: paso 6, imagen 2 de 2
    • Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis.
    Pregunta a FixBot
    Agregar Comentario
  7. Logitech K120 Keyboard USB Cable Replacement, Removing The Membrane: paso 7, imagen 1 de 2 Logitech K120 Keyboard USB Cable Replacement, Removing The Membrane: paso 7, imagen 2 de 2
    • Peel the membrane off carefully so that the membrane doesn't rip.
    Pregunta a FixBot
    Agregar Comentario
  8. Logitech K120 Keyboard USB Cable Replacement, Remove The 2nd Membrane: paso 8, imagen 1 de 3 Logitech K120 Keyboard USB Cable Replacement, Remove The 2nd Membrane: paso 8, imagen 2 de 3 Logitech K120 Keyboard USB Cable Replacement, Remove The 2nd Membrane: paso 8, imagen 3 de 3
    • Stick the sharp end of the spudger into the corner of the second membrane and bring the spudger partly underneath the membrane.
    • Lift the membrane off of the first standoff.
    • Peel the rest of the membrane off carefully so the membrane doesn't rip.
    Pregunta a FixBot
    Agregar Comentario
  9. Logitech K120 Keyboard USB Cable Replacement, Install The New Cable: paso 9, imagen 1 de 3 Logitech K120 Keyboard USB Cable Replacement, Install The New Cable: paso 9, imagen 2 de 3 Logitech K120 Keyboard USB Cable Replacement, Install The New Cable: paso 9, imagen 3 de 3
    • Slide the new cable into the hole.
    Pregunta a FixBot
    Agregar Comentario
  10. Logitech K120 Keyboard USB Cable Replacement, Connect The New Cable: paso 10, imagen 1 de 3 Logitech K120 Keyboard USB Cable Replacement, Connect The New Cable: paso 10, imagen 2 de 3 Logitech K120 Keyboard USB Cable Replacement, Connect The New Cable: paso 10, imagen 3 de 3
    • Connect The Cable To The Circuit Board.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
To reassemble your device, follow the instructions on how to reassemble your device in the prerequisite guide.
Una persona más ha completado esta guía.
Camuise
Miembro Desde 11/22/18
1,675 Reputación
7 Guías creadas
4Guía Comentarios
Hi there,
Nice guide! Where do I get hold of a replacement USB wire / what’s the specific name of it?
Thanks,
Robin
Robin Lane - Contestar Compartir
Great question. I found most of these replacement cables are on ebay or amazon as logitech mouse cable replacements.
Bri Gipson - Contestar Compartir
Search the web (or Amazon) for the following:
USB Line Wire Cable Replacement Repair Logitech
hi can u send the link of cable from where u buy it
khadija emaan - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 21
Ultimos 30 días: 98
Todo El Tiempo: 4,582
