Saltar al contenido principal
Logitech Harmony Ultimate Charging Station Motherboard Replacement
Qué necesitas
  1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: paso 1, imagen 1 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: paso 1, imagen 2 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: paso 1, imagen 3 de 3
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove four 6mm screws Phillips #0 screws from the bottom of the device.
  2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: paso 2, imagen 1 de 2 Logitech Harmony Ultimate Charging Station Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to remove top shell from device.
  3. Logitech Harmony Ultimate Charging Station Motherboard Replacement: paso 3, imagen 1 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: paso 3, imagen 2 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the two (4mm) screws using Phillips 1 screwdriver.
  4. Logitech Harmony Ultimate Charging Station Motherboard Replacement: paso 4, imagen 1 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: paso 4, imagen 2 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: paso 4, imagen 3 de 3
    • Use the Phillips #0 screwdriver to remove the last (4mm) screw. The motherboard can now be removed.
Conclusión
Lucas Reynolds
Miembro Desde 09/01/15
339 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-1, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 22
Todo El Tiempo: 2,908
