Introducción
If you find that your remote control touchscreen has stopped working correctly or has been damaged, you may need to replace it in order to continue using the device. This guide will help you to access the touchscreen of the Logitech Harmony remote universal.
Qué necesitas
Open the latch that accesses the charging port.
Remove the black sticker and remove the screw with the indicated screw driver.
Take the plastic opening tool and run it down the side of the remote to pop the case open.
Detach the white clamp to partially disconnect the case from the motherboard.
Una persona más ha completado esta guía.
2 comentarios
do you have the lcd screen P/N???
