Saltar al contenido principal
Logitech Harmony Touch Motherboard Replacement
Qué necesitas
  1. Logitech Harmony Touch Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Open the latch that accesses the charging port
    • Remove the black sticker and remove the screw with the indicated screwdriver
    • Take the plastic opening tool and run it down the side of the remote to pop the case open
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out
    • Detach the white clamp to partially disconnect the case from the motherboard
  2. Logitech Harmony Touch Motherboard Replacement: paso 2, imagen 1 de 3 Logitech Harmony Touch Motherboard Replacement: paso 2, imagen 2 de 3 Logitech Harmony Touch Motherboard Replacement: paso 2, imagen 3 de 3
    • Peel back thin yellow plastic film and detach the clip found underneath
    • Remove the screws that connect the motherboard to the case with the suggested screwdriver
    • Next, carefully remove the motherboard from the top piece of the case
    • The motherboard is connected to the bottom part of the case
    • You should now be able to access all of the buttons and remove them from the case
Conclusión
Equipo
USF Tampa, Team S4-G2, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 725
