Saltar al contenido principal
Logitech Harmony Touch Buttons Replacement
Qué necesitas
  1. Logitech Harmony Touch Buttons Replacement, Buttons: paso 1, imagen 1 de 3 Logitech Harmony Touch Buttons Replacement, Buttons: paso 1, imagen 2 de 3 Logitech Harmony Touch Buttons Replacement, Buttons: paso 1, imagen 3 de 3
    • Open the latch that accesses the charging port.
    • Remove the black sticker and the screw with the Phillips #0 Screwdriver.
    • Take the plastic opening tool and run it down the side of the remote to open the case.
    • While doing this step, three wires connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to disconnect the case from the motherboard partially.
  2. Logitech Harmony Touch Buttons Replacement: paso 2, imagen 1 de 3 Logitech Harmony Touch Buttons Replacement: paso 2, imagen 2 de 3 Logitech Harmony Touch Buttons Replacement: paso 2, imagen 3 de 3
    • Peel back the thin yellow plastic film.
    • Detach the clip found underneath the film.
    • Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
  3. Logitech Harmony Touch Buttons Replacement: paso 3, imagen 1 de 3 Logitech Harmony Touch Buttons Replacement: paso 3, imagen 2 de 3 Logitech Harmony Touch Buttons Replacement: paso 3, imagen 3 de 3
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all the buttons and remove them from the case.
  4. Logitech Harmony Touch Buttons Replacement: paso 4, imagen 1 de 2 Logitech Harmony Touch Buttons Replacement: paso 4, imagen 2 de 2
    • Remove the buttons from the case.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S4-G2, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 1,372
