Saltar al contenido principal
Logitech Harmony Smart Keyboard On/Off Switch Replacement
Qué necesitas
  1. Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: paso 1, imagen 1 de 2 Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: paso 1, imagen 2 de 2
    • Turn keyboard over to the backside.
  2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 2, imagen 1 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 2, imagen 2 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 2, imagen 3 de 3
    • Press and slide up on the upper battery latch, using both thumbs.
  3. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 3, imagen 1 de 1
    • Remove the two AA batteries and set them aside.
  4. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 4, imagen 1 de 2 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 4, imagen 2 de 2
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
  5. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 5, imagen 1 de 2 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 5, imagen 2 de 2
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
  6. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 6, imagen 1 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 6, imagen 2 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 6, imagen 3 de 3
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
  7. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 7, imagen 1 de 2 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 7, imagen 2 de 2
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
  8. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 8, imagen 1 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 8, imagen 2 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 8, imagen 3 de 3
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
  9. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 9, imagen 1 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 9, imagen 2 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 9, imagen 3 de 3
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
  10. Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: paso 10, imagen 1 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: paso 10, imagen 2 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: paso 10, imagen 3 de 3
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
  11. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 11, imagen 1 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 11, imagen 2 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 11, imagen 3 de 3
    • Set aside the front panel and locate the green card atop the on/off switch on the back panel.
    • Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
  12. Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 12, imagen 1 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 12, imagen 2 de 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: paso 12, imagen 3 de 3
    • Lift up and hold the left side of the green card with one index finger.
    • Grip and pull the on/off switch out with your other index finger and thumb.
Conclusión
2 personas más completaron esta guía.
Hayley Nichols
Miembro Desde 09/05/17
525 Reputación
4 Guías creadas
Equipo
CSU Fullerton, Team S1-G2, Bruce Fall 2017 Miembro de CSU Fullerton, Team S1-G2, Bruce Fall 2017
CSUF-BRUCE-F17S1G2
3 Miembros
10 Guías creadas
Un comentario
please share switch rear side.. and where could we buy this switch.. ?
Praveen Krishnan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 41
Todo El Tiempo: 4,110
