Saltar al contenido principal
Logitech Harmony Smart Control Reset Button Replacement
Qué necesitas
  1. Logitech Harmony Smart Control Reset Button Replacement, Reset Button: paso 1, imagen 1 de 2 Logitech Harmony Smart Control Reset Button Replacement, Reset Button: paso 1, imagen 2 de 2
    • Using a plastic opening tool, lift up the rubber pad.
    • From the bottom of the device, with your fingers, pull back the rubber pad. This will expose the screw holes.
    • On the bottom of the hub, repeat the step above for the second rubber pad.
  2. Logitech Harmony Smart Control Reset Button Replacement: paso 2, imagen 1 de 2 Logitech Harmony Smart Control Reset Button Replacement: paso 2, imagen 2 de 2
    • With the PH00 bit, remove the four 6mm Phillips screws.
  3. Logitech Harmony Smart Control Reset Button Replacement: paso 3, imagen 1 de 2 Logitech Harmony Smart Control Reset Button Replacement: paso 3, imagen 2 de 2
    • With the plastic opening tool, separate the pieces of plastic from each other
  4. Logitech Harmony Smart Control Reset Button Replacement: paso 4, imagen 1 de 2 Logitech Harmony Smart Control Reset Button Replacement: paso 4, imagen 2 de 2
    • With the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Reset Button Replacement: paso 5, imagen 1 de 3 Logitech Harmony Smart Control Reset Button Replacement: paso 5, imagen 2 de 3 Logitech Harmony Smart Control Reset Button Replacement: paso 5, imagen 3 de 3
    • From the yellow corner, pry the circuit board from the housing..
  6. Logitech Harmony Smart Control Reset Button Replacement: paso 6, imagen 1 de 3 Logitech Harmony Smart Control Reset Button Replacement: paso 6, imagen 2 de 3 Logitech Harmony Smart Control Reset Button Replacement: paso 6, imagen 3 de 3
    • Locate the defective reset button.
    • Turn the board around to expose the reset solder.
    • Using soldering iron, remove solder and reset button. Replace reset button and solder.
Conclusión
Equipo
IUPUI, Team 3-2, Harley Fall 2015 Miembro de IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 963
