Saltar al contenido principal
Logitech Harmony Smart Control Remote Buttons Replacement
Qué necesitas
  1. Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: paso 1, imagen 1 de 2 Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: paso 1, imagen 2 de 2
    • With both thumbs, slide the grooved cover off the end of the remote.
    • Remove the battery once cover is removed.
  2. Logitech Harmony Smart Control Remote Buttons Replacement: paso 2, imagen 1 de 2 Logitech Harmony Smart Control Remote Buttons Replacement: paso 2, imagen 2 de 2
    • With the PH00 bit, remove both of the 4mm Phillip screws on the remote.
  3. Logitech Harmony Smart Control Remote Buttons Replacement: paso 3, imagen 1 de 2 Logitech Harmony Smart Control Remote Buttons Replacement: paso 3, imagen 2 de 2
    • Using a metal spudger, pry the remote. Maneuver around to separate both sides.
  4. Logitech Harmony Smart Control Remote Buttons Replacement: paso 4, imagen 1 de 3 Logitech Harmony Smart Control Remote Buttons Replacement: paso 4, imagen 2 de 3 Logitech Harmony Smart Control Remote Buttons Replacement: paso 4, imagen 3 de 3
    • Manualy separate the two pieces of plastic.
    • Using the metal piece from the housing, pry up the circuit board. Do not disconnect anything.
    • When the circuit board is pried, slide the circuit board out of the housing.
  5. Logitech Harmony Smart Control Remote Buttons Replacement: paso 5, imagen 1 de 1
    • From the front of the remote, remove the buttons. Clean or replace the necessary buttons.
Conclusión
2 personas más completaron esta guía.
Josh Hendricks
Miembro Desde 09/17/15
464 Reputación
4 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Fall 2015 Miembro de IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Miembros
5 Guías creadas
9 comentarios
Excellent guide. However, I can’t find a supplier for the button pad. Any suggestions?
fhaist - Contestar
Hi there,
My son dropped mine in water. I opened it and dried it off but it still doesn’t work.
I could give you my button pad if you want.
Benoit Lagarde -
Where do you purchase button replacements?
Steve Lutes - Contestar
Flavio Campos - Contestar
Excellent! I wasn’t sure if it was possible to crack it open or not. Thanks, I was able to clean it up.
John Wall - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 34
Todo El Tiempo: 5,715
