Saltar al contenido principal
Logitech Harmony Smart Control Hub Light Bulb Replacement
Qué necesitas
  1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: paso 1, imagen 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: paso 1, imagen 2 de 2
    • Use a spudger to lift up one of the rubber pads on the bottom of the hub.
    • Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
    • Repeat for the second rubber pad.
  2. Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 2, imagen 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 2, imagen 2 de 2
    • Use a PH00 screwdriver bit to remove the four 6mm Phillips screws on the bottom of the device.
  3. Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 3, imagen 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 3, imagen 2 de 2
    • Use a spudger to separate the top and bottom pieces of the device.
  4. Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 4, imagen 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 4, imagen 2 de 2
    • Use the PH00 screwdriver bit to unscrew the three 4mm Phillips screws on the control board.
  5. Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 5, imagen 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 5, imagen 2 de 2
    • Place the end of the opening tool under the yellow corner of the circuit board as shown.
    • Gently push upward to pry the board from its housing.
  6. Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 6, imagen 1 de 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 6, imagen 2 de 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: paso 6, imagen 3 de 3
    • Determine which of the five bulbs are defective.
    • Turn the board over to expose the bulb solder.
    • Using a soldering iron, remove the solder and bulb. Replace with a new bulb and re-solder.
Conclusión
2 personas más completaron esta guía.
Josh Hendricks
Miembro Desde 09/17/15
464 Reputación
4 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Fall 2015 Miembro de IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 557
