Saltar al contenido principal
Logitech Harmony Smart Control Charging Port Replacement
Qué necesitas
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: paso 1, imagen 1 de 2 Logitech Harmony Smart Control Charging Port Replacement, Charging Port: paso 1, imagen 2 de 2
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: paso 2, imagen 1 de 2 Logitech Harmony Smart Control Charging Port Replacement: paso 2, imagen 2 de 2
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: paso 3, imagen 1 de 2 Logitech Harmony Smart Control Charging Port Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: paso 4, imagen 1 de 2 Logitech Harmony Smart Control Charging Port Replacement: paso 4, imagen 2 de 2
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: paso 5, imagen 1 de 3 Logitech Harmony Smart Control Charging Port Replacement: paso 5, imagen 2 de 3 Logitech Harmony Smart Control Charging Port Replacement: paso 5, imagen 3 de 3
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: paso 6, imagen 1 de 3 Logitech Harmony Smart Control Charging Port Replacement: paso 6, imagen 2 de 3 Logitech Harmony Smart Control Charging Port Replacement: paso 6, imagen 3 de 3
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
Conclusión
Una persona más ha completado esta guía.
Josh Hendricks
Miembro Desde 09/17/15
464 Reputación
4 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Fall 2015 Miembro de IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 718
