Saltar al contenido principal
Logitech Harmony Smart Control Battery Contact Replacement
Qué necesitas
  1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: paso 1, imagen 1 de 2 Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: paso 1, imagen 2 de 2
    • Use both thumbs to slide the grooved cover off of the remote
    • Once the cover is off, remove the battery.
  2. Logitech Harmony Smart Control Battery Contact  Replacement: paso 2, imagen 1 de 2 Logitech Harmony Smart Control Battery Contact  Replacement: paso 2, imagen 2 de 2
    • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
  3. Logitech Harmony Smart Control Battery Contact  Replacement: paso 3, imagen 1 de 3 Logitech Harmony Smart Control Battery Contact  Replacement: paso 3, imagen 2 de 3 Logitech Harmony Smart Control Battery Contact  Replacement: paso 3, imagen 3 de 3
    • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
  4. Logitech Harmony Smart Control Battery Contact  Replacement: paso 4, imagen 1 de 2 Logitech Harmony Smart Control Battery Contact  Replacement: paso 4, imagen 2 de 2
    • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
    • Slide the circuit board out from the housing .
  5. Logitech Harmony Smart Control Battery Contact  Replacement: paso 5, imagen 1 de 1
    • Locate the battery contacts on the circuit board.
    • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
Conclusión
Josh Hendricks
Miembro Desde 09/17/15
464 Reputación
4 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Fall 2015 Miembro de IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Miembros
5 Guías creadas
Un comentario
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 31
Todo El Tiempo: 4,977
