Saltar al contenido principal
Logitech Harmony Companion Remote Motherboard Replacement
Qué necesitas
  1. Logitech Harmony Companion Remote Motherboard Replacement, Remote Battery: paso 1, imagen 1 de 1
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Remote Motherboard Replacement: paso 2, imagen 1 de 1
    • Push the battery cover upward.
  3. Logitech Harmony Companion Remote Motherboard Replacement: paso 3, imagen 1 de 3 Logitech Harmony Companion Remote Motherboard Replacement: paso 3, imagen 2 de 3 Logitech Harmony Companion Remote Motherboard Replacement: paso 3, imagen 3 de 3
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: paso 4, imagen 1 de 2 Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: paso 4, imagen 2 de 2
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Remote Motherboard Replacement: paso 5, imagen 1 de 2 Logitech Harmony Companion Remote Motherboard Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Remote Motherboard Replacement: paso 6, imagen 1 de 2 Logitech Harmony Companion Remote Motherboard Replacement: paso 6, imagen 2 de 2
    • Use the plastic opening tool to remove the motherboard.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G3, Nance Fall 2017 Miembro de USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Miembros
4 Guías creadas
Un comentario
Any source on that motherboard? I've got two dead buttons and replacement remotes are expensive and hard to come by.
Karl Wooster - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 23
Ultimos 30 días: 103
Todo El Tiempo: 5,860
