Saltar al contenido principal
Logitech Harmony 950 Battery Replacement
Qué necesitas
  1. Logitech Harmony 950 Battery Replacement, Battery: paso 1, imagen 1 de 2 Logitech Harmony 950 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the remote control is powered off before starting.
    • Use the Opening Tool to open the port cover at the bottom of the remote control.
    • Bend the cover back to gain easy access to the screws.
  2. Logitech Harmony 950 Battery Replacement: paso 2, imagen 1 de 3 Logitech Harmony 950 Battery Replacement: paso 2, imagen 2 de 3 Logitech Harmony 950 Battery Replacement: paso 2, imagen 3 de 3
    • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
    • Pull the bottom cover off of the remote control.
  3. Logitech Harmony 950 Battery Replacement: paso 3, imagen 1 de 3 Logitech Harmony 950 Battery Replacement: paso 3, imagen 2 de 3 Logitech Harmony 950 Battery Replacement: paso 3, imagen 3 de 3
    • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
    • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  4. Logitech Harmony 950 Battery Replacement: paso 4, imagen 1 de 3 Logitech Harmony 950 Battery Replacement: paso 4, imagen 2 de 3 Logitech Harmony 950 Battery Replacement: paso 4, imagen 3 de 3
    • Use the Opening Tool to lift the battery out of the case.
    • Gently pull the cable out of the socket to unplug the battery.
    • Be careful not to damage any part of the remote when pulling the cable out.
Conclusión
8 personas más completaron esta guía.
Blake Sanborn
Miembro Desde 09/26/17
546 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S2-G2, Passmore Fall 2017 Miembro de USF Tampa, Team S2-G2, Passmore Fall 2017
USFT-PASSMORE-F17S2G2
4 Miembros
4 Guías creadas
3 comentarios
And where to buy these batteries?
Rene A - Contestar
Still no batteries for this unit? Maybe Amazon?
Dan - Contestar
|Just checked, and batteries are available on Amazon from several vendors. Mine is on its last legs, so I have ordered one.
Mac Samildanach -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 67
Todo El Tiempo: 4,904
