Saltar al contenido principal
Logitech Harmony 900 Motherboard Replacement
Qué necesitas
  1. Logitech Harmony 900 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Logitech Harmony 900 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Press the oval shaped button on the lower back of the remote to release the battery cover.
    • While pressing the button, remove the cover.
  2. Logitech Harmony 900 Motherboard Replacement: paso 2, imagen 1 de 2 Logitech Harmony 900 Motherboard Replacement: paso 2, imagen 2 de 2
    • Push the battery in, pull it up, and slide it out.
  3. Logitech Harmony 900 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
  4. Logitech Harmony 900 Motherboard Replacement: paso 4, imagen 1 de 2 Logitech Harmony 900 Motherboard Replacement: paso 4, imagen 2 de 2
    • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
  5. Logitech Harmony 900 Motherboard Replacement: paso 5, imagen 1 de 1
    • Use a credit card to pry the black, plastic, back cover off of the device.
    • You may need to get the process started with a metal prying tool before you start using the credit card.
  6. Logitech Harmony 900 Motherboard Replacement: paso 6, imagen 1 de 2 Logitech Harmony 900 Motherboard Replacement: paso 6, imagen 2 de 2
    • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
  7. Logitech Harmony 900 Motherboard Replacement: paso 7, imagen 1 de 2 Logitech Harmony 900 Motherboard Replacement: paso 7, imagen 2 de 2
    • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
    • Again, you may need to use a metal prying tool to get the separation started.
  8. Logitech Harmony 900 Motherboard Replacement: paso 8, imagen 1 de 2 Logitech Harmony 900 Motherboard Replacement: paso 8, imagen 2 de 2
    • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
    • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
  9. Logitech Harmony 900 Motherboard Replacement: paso 9, imagen 1 de 2 Logitech Harmony 900 Motherboard Replacement: paso 9, imagen 2 de 2
    • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
  10. Logitech Harmony 900 Motherboard Replacement: paso 10, imagen 1 de 1
    • Using your hands, carefully separate the motherboard from the rest of the remote.
Conclusión
To reassemble, follow the steps in reverse order.
John Adams
Miembro Desde 09/25/17
116 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S4-G5, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G5, Eyestone Fall 2017
USFT-EYESTONE-F17S4G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 560
