Saltar al contenido principal
Logitech Harmony 650 Screen Replacement
Qué necesitas
  1. Logitech Harmony 650 Screen Replacement, Case: paso 1, imagen 1 de 2 Logitech Harmony 650 Screen Replacement, Case: paso 1, imagen 2 de 2
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
  2. Logitech Harmony 650 Screen Replacement: paso 2, imagen 1 de 1
    • Remove the batteries using the silver pull tab.
  3. Logitech Harmony 650 Screen Replacement: paso 3, imagen 1 de 1
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
  4. Logitech Harmony 650 Screen Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
  5. Logitech Harmony 650 Screen Replacement: paso 5, imagen 1 de 1
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
  6. Logitech Harmony 650 Screen Replacement: paso 6, imagen 1 de 2 Logitech Harmony 650 Screen Replacement: paso 6, imagen 2 de 2
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
  7. Logitech Harmony 650 Screen Replacement: paso 7, imagen 1 de 1
    • Remove the rear cover.
  8. Logitech Harmony 650 Screen Replacement, Motherboard: paso 8, imagen 1 de 2 Logitech Harmony 650 Screen Replacement, Motherboard: paso 8, imagen 2 de 2
    • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
  9. Logitech Harmony 650 Screen Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard by gently pulling it away from the case.
  10. Logitech Harmony 650 Screen Replacement, Screen: paso 10, imagen 1 de 2 Logitech Harmony 650 Screen Replacement, Screen: paso 10, imagen 2 de 2
    • Remove the black rubber gasket that surrounds the screen from the top face of the motherboard.
    • The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
  11. Logitech Harmony 650 Screen Replacement: paso 11, imagen 1 de 1
    • Use a soldering iron to loosen the solder that connects the screen strip to the back of the motherboard. If it does not loosen easily then try using a soldering remover wick.
    • The soldering iron gets extremely hot use caution when using it around components.
  12. Logitech Harmony 650 Screen Replacement: paso 12, imagen 1 de 1
  13. Logitech Harmony 650 Screen Replacement: paso 13, imagen 1 de 1
    • Use a spudger or your hand to remove the screen from the motherboard. It is glued down.
Conclusión
4 personas más completaron esta guía.
2 comentarios
Hey will beat buy honor a warrenty
antonioofficial - Contestar
so where can i buy the screen!!!!
shortemperd Gotico - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 2,794
