Saltar al contenido principal
Logitech Harmony 650 Motherboard Replacement
Qué necesitas
  1. Logitech Harmony 650 Motherboard Replacement, Case: paso 1, imagen 1 de 2 Logitech Harmony 650 Motherboard Replacement, Case: paso 1, imagen 2 de 2
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
  2. Logitech Harmony 650 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the batteries using the silver pull tab.
  3. Logitech Harmony 650 Motherboard Replacement: paso 3, imagen 1 de 1
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
  4. Logitech Harmony 650 Motherboard Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
  5. Logitech Harmony 650 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
  6. Logitech Harmony 650 Motherboard Replacement: paso 6, imagen 1 de 2 Logitech Harmony 650 Motherboard Replacement: paso 6, imagen 2 de 2
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
  7. Logitech Harmony 650 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the rear cover.
  8. Logitech Harmony 650 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 2 Logitech Harmony 650 Motherboard Replacement, Motherboard: paso 8, imagen 2 de 2
    • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
  9. Logitech Harmony 650 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard by gently pulling it away from the case.
Conclusión
10 personas más completaron esta guía.
5 comentarios
Thanks! Remote was dropped in water tonight & I used this to take it apart for a thorough drying out.
tedcmacdonald - Contestar
anyone know where I can purchase the motherboard for this model? Logitech does not sell them
howardgis - Contestar
I assume nobody sells the motherboard as a spare part? Pity, mine 650’s dead!
Chris Phillips -
Thank you so much for the instructions. Some buttons of my Harmony 650 were not responding and I was able to open it and clean with alcohol the rubber pins and their peer circuit board conductor traces. After that all works as new !
Gia-khanh Nguyen - Contestar
Thank you for the very helpful information on how to disassemble the remote. I have been having problems with some of the buttons not working very well for a long time. I was able to clean all the button contact surfaces, and now all the buttons operate. Something that simple means a lot. Thank you again.
SkyCaptain000 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 4,719
