Introducción
If your joysticks are cracked, old, or broken, you may want to replace them. Joysticks are key for any game you might play. Follow this guide to replace your joysticks. The joystick are used to move around in games on pc.
No special tools or skills are required.
Qué necesitas
Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
Casi Terminas!
You're finished! To reassemble your device, follow these instructions in reverse order.
Conclusión
