Saltar al contenido principal
Logitech Gamepad F310 Disassembly
Qué necesitas
  1. Logitech Gamepad F310 Disassembly, Case: paso 1, imagen 1 de 2 Logitech Gamepad F310 Disassembly, Case: paso 1, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
  2. Logitech Gamepad F310 Disassembly: paso 2, imagen 1 de 2 Logitech Gamepad F310 Disassembly: paso 2, imagen 2 de 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
  3. Logitech Gamepad F310 Disassembly: paso 3, imagen 1 de 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 66
Todo El Tiempo: 115
