Saltar al contenido principal
Logitech Gamepad F310 Bumpers Replacement
Qué necesitas
  1. Logitech Gamepad F310 Bumpers Replacement, Case: paso 1, imagen 1 de 2 Logitech Gamepad F310 Bumpers Replacement, Case: paso 1, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
  2. Logitech Gamepad F310 Bumpers Replacement: paso 2, imagen 1 de 2 Logitech Gamepad F310 Bumpers Replacement: paso 2, imagen 2 de 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
  3. Logitech Gamepad F310 Bumpers Replacement: paso 3, imagen 1 de 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
  4. Logitech Gamepad F310 Bumpers Replacement, Bumpers: paso 4, imagen 1 de 2 Logitech Gamepad F310 Bumpers Replacement, Bumpers: paso 4, imagen 2 de 2
    • Grip the bumper and pull directly up to remove it.
    • Repeat for the other side if necessary.
Conclusión
You're all finished! To reassemble your device, follow these instructions in reverse order.
Graydon
Miembro Desde 02/05/24
145 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 37
Todo El Tiempo: 107
