Saltar al contenido principal
Logitech G915 Wireless (Clicky) Battery Removal
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Logitech G915 Wireless (Clicky) Battery Removal, Battery: paso 1, imagen 1 de 1
    • Peel back the label and unscrew the two #0 Phillips screws.
  2. Logitech G915 Wireless (Clicky) Battery Removal: paso 2, imagen 1 de 2 Logitech G915 Wireless (Clicky) Battery Removal: paso 2, imagen 2 de 2
    • Slide and lift the battery compartment until it lifts from the body of the keyboard.
    • Disconnect the battery connector to remove the battery from the keyboard.
Conclusión
6 personas más completaron esta guía.
Julian
Miembro Desde 03/23/16
709 Reputación
3 Guías creadas
9Guía Comentarios
HI, CAN YOU use the keyboard with a micro usb cable to a phone charger and without a battery connected? (not cabled to the computer)
eckndu - Contestar
You can’t cause it acts the battery as the power source even though you have cable connected to it (tried it myself on g903)… so sooner or later you have to replace the battery or you just use it wired forever cause the degradation of battery
Blizzard Wind -
ok. confirm you can run it without a batt
eckndu -
actually you can - I blew my battery up trying to mount a couple of screws through the battery cover to a VESA monitor arm - lots of smoke and a crispy battery later… the G915 is working perfectly fine with no battery and just the USB-C plugged in :D
Sinister Intent - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 31
Todo El Tiempo: 18,267
