Saltar al contenido principal
Introducción
This guide will teach you how to replace the power cord of your device. It's a relatively easy process, and you won't be needing any special skills.
Partes
No se especificaron partes.
  1. Turn over the keyboard and remove the three screws using a Phillips #0 screwdriver.
    • Turn over the keyboard and remove the three screws using a Phillips #0 screwdriver.
  2. Remove  the USB from the keyboard.
    • Remove the USB from the keyboard.
  3. Make sure the cord tab is not broken.
    • Make sure the cord tab is not broken.
  4. If the cord tab is not broken, close it back.
    • If the cord tab is not broken, close it back.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 7
Últimos 30 Días: 49
Todo El Tiempo: 628
