Introducción
This guide will help you remove a key from the keyboard of your Logitech G910 Keyboard and replace it with a new one. You will need a key cap remover however it is not required but many might find it easier to use a key cap remover.
Qué necesitas
Unplug the keyboards USB cord from the computer. This is to ensure it is powered off.
Make sure the keyboard is facing up towards you and on a level and sturdy surface.
Gently use your fingers to remove the key caps from the keyboard by firmly grasping the key and pulling directly up.
Make sure the pins line up and it is facing the correct direction. Once you have done this, firmly push it in until you hear it click into place and works like normal again.
8 personas más completaron esta guía.
13 comentarios
I am sorry, but why did you wrote a tutorial and describe how to open up G910 (and lose the warranty along the way) just to take of the keyCAP?
Keycap can be removed in a matter of seconds with use of $0.99 keycap removal tool
It’s not just the Key Cap, you can remove the mechanical switch too. I have a busted G910 and I’ve been wanting to replace the switches for a while now.
dude same, I have a few broken switches on mine that I'm keeping held together with some wadded up paper. the 9 key is completely gone sadly.
I think step 3 and 4 are in the wrong order, you can’t get to the screws until you get that face-plate off
