Saltar al contenido principal
Logitech G432 Volume Button Replacement
Qué necesitas
  1. Logitech G432 Volume Button Replacement, Earpad Cushions: paso 1, imagen 1 de 2 Logitech G432 Volume Button Replacement, Earpad Cushions: paso 1, imagen 2 de 2
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Volume Button Replacement, Volume Button: paso 2, imagen 1 de 3 Logitech G432 Volume Button Replacement, Volume Button: paso 2, imagen 2 de 3 Logitech G432 Volume Button Replacement, Volume Button: paso 2, imagen 3 de 3
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Volume Button Replacement: paso 3, imagen 1 de 1
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
  4. Logitech G432 Volume Button Replacement: paso 4, imagen 1 de 2 Logitech G432 Volume Button Replacement: paso 4, imagen 2 de 2
    • To adjust and fix the volume button, use a Phillips #0 screwdriver to tighten, loosen, or remove the 1.0 mm screw located on the left side.
Conclusión
Lara Vasquez
Miembro Desde 02/24/23
397 Reputación
4 Guías creadas
Equipo
Marist, Team 1-2, Chaterdon Spring 2023 Miembro de Marist, Team 1-2, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G2
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 44
Todo El Tiempo: 424
