Saltar al contenido principal
Logitech G432 Speaker Replacement
Qué necesitas
  1. Logitech G432 Speaker Replacement, Earpad Cushions: paso 1, imagen 1 de 2 Logitech G432 Speaker Replacement, Earpad Cushions: paso 1, imagen 2 de 2
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Speaker Replacement, Speaker: paso 2, imagen 1 de 3 Logitech G432 Speaker Replacement, Speaker: paso 2, imagen 2 de 3 Logitech G432 Speaker Replacement, Speaker: paso 2, imagen 3 de 3
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Speaker Replacement: paso 3, imagen 1 de 1
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
  4. Logitech G432 Speaker Replacement: paso 4, imagen 1 de 2 Logitech G432 Speaker Replacement: paso 4, imagen 2 de 2
    • Using an iFixit opening tool, separate the four black tabs by pushing them away from each other to unclip them.
    • Gently pull apart the outside shell of the headpiece to reveal the speaker.
Conclusión
Lara Vasquez
Miembro Desde 02/24/23
397 Reputación
4 Guías creadas
Equipo
Marist, Team 1-2, Chaterdon Spring 2023 Miembro de Marist, Team 1-2, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G2
3 Miembros
9 Guías creadas
Un comentario
Hey, I have issues trying to remove the speaker itself from the other piece, so I cant place the new one, any suggestions?
Cristian Eduardo Ramirez Silva - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 48
Todo El Tiempo: 479
