Saltar al contenido principal
Logitech G29 Driving Force Paddle Assembly Replacement
Qué necesitas
  1. Logitech G29 Driving Force Paddle Assembly Replacement, Paddle Assembly: paso 1, imagen 1 de 1
    • Remove the six 32mm long 4mm allen screws from the faceplate of the steering wheel
  2. Logitech G29 Driving Force Paddle Assembly Replacement: paso 2, imagen 1 de 1
    • Now, Remove the six 10mm long #00 Phillips head screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
  3. Logitech G29 Driving Force Paddle Assembly Replacement: paso 3, imagen 1 de 1
    • Carefully unplug the wire connector from the motherboard of the steering wheel
  4. Logitech G29 Driving Force Paddle Assembly Replacement: paso 4, imagen 1 de 1
    • Using the #1 Phillips head screwdriver remove the three 30mm long screws that are behind the steering wheel.
  5. Logitech G29 Driving Force Paddle Assembly Replacement: paso 5, imagen 1 de 1
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 50
Ultimos 30 días: 234
Todo El Tiempo: 1,049
