Saltar al contenido principal
Logitech G29 Driving Force Buttons Replacement
Qué necesitas
  1. Logitech G29 Driving Force Buttons Replacement, Buttons: paso 1, imagen 1 de 3 Logitech G29 Driving Force Buttons Replacement, Buttons: paso 1, imagen 2 de 3 Logitech G29 Driving Force Buttons Replacement, Buttons: paso 1, imagen 3 de 3
    • Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
    • The wheel is still attached the base via a bundled cable-connector.
  2. Logitech G29 Driving Force Buttons Replacement: paso 2, imagen 1 de 3 Logitech G29 Driving Force Buttons Replacement: paso 2, imagen 2 de 3 Logitech G29 Driving Force Buttons Replacement: paso 2, imagen 3 de 3
    • Gently lift the faceplate and wheel off the stand.
    • Pull the white 7-pin cable connector from the wheel PCB.
    • Use a spudger or plastic opening tool to help free the connector at its base. Do not pull on the wires.
  3. Logitech G29 Driving Force Buttons Replacement: paso 3, imagen 1 de 2 Logitech G29 Driving Force Buttons Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the seven 4.32 mm diameter, 8mm long silver screws that secure the main wheel PCB.
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw from the Share/Options/PlayStation button PCB.
  4. Logitech G29 Driving Force Buttons Replacement: paso 4, imagen 1 de 3 Logitech G29 Driving Force Buttons Replacement: paso 4, imagen 2 de 3 Logitech G29 Driving Force Buttons Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    $3.99
    • Once the PCB is out, the triangle, square, circle, x button will be exposed. Use the angled tweezers to remove all four buttons.
    • These buttons are keyed to where only a certain key will fit in a certain spot.
  5. Logitech G29 Driving Force Buttons Replacement: paso 5, imagen 1 de 1
    • Once the PCB is out, the D-PAD will fall out as well. Use the angled tweezers to remove the D-PAD.
    • This is also keyed to where it can only fit in a certain direction.
  6. Logitech G29 Driving Force Buttons Replacement: paso 6, imagen 1 de 3 Logitech G29 Driving Force Buttons Replacement: paso 6, imagen 2 de 3 Logitech G29 Driving Force Buttons Replacement: paso 6, imagen 3 de 3
    • Remove the 4 black screws diameter of 3.41mm length 5mm holding the 4 buttons in place using the Ph #00 bit. These are located directly under the buttons.
    • The whole housing is not required to come out since only the blue buttons need to come out. Once the screws are removed the buttons will fall out.
  7. Logitech G29 Driving Force Buttons Replacement: paso 7, imagen 1 de 1
    • Remove the 4 black screws diameter of 3.41mm holding the 4 buttons in place using the Ph #00 bit. These are located directly under the buttons. The whole housing is not required to come out since only the blue buttons need to come out. Once the screws are removed the buttons will fall out.
Conclusión
Ben varner
Miembro Desde 11/08/23
400 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-3, Harley Fall 2023 Miembro de IUPUI, Team 1-3, Harley Fall 2023
IUPUI-HARLEY-F23S1G3
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 26
Ultimos 30 días: 137
Todo El Tiempo: 2,248
