Introducción
If the C-Clamps on your Logitech G27 break, you will need to replace them before using the steering wheel again. This is a little bit of a pain to do, because the C-Clamps are fully inside the device case. To replace them, you will just need to remove a few screws.
Qué necesitas
Remove the six gray 25mm hex screws with a 4mm allen wrench.
Carefully lift up the wheel, but do not disconnect it from the rest of the device.
23 personas más completaron esta guía.
14 comentarios
Where would I buy the replacement C-Clamps from because one of mine are broken and I need to install a new one.
Look for it at eBay.
Eduardo -
I also need to find a place to buy replacement C-clamps from
