Saltar al contenido principal
Logitech Extreme 3D Pro Top button circuit board Replacement
Qué necesitas
  1. Logitech Extreme 3D Pro Top button circuit board Replacement, Disassembly of the handle: paso 1, imagen 1 de 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Top button circuit board Replacement: paso 2, imagen 1 de 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Top button circuit board Replacement: paso 3, imagen 1 de 2 Logitech Extreme 3D Pro Top button circuit board Replacement: paso 3, imagen 2 de 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: paso 4, imagen 1 de 3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: paso 4, imagen 2 de 3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: paso 4, imagen 3 de 3
    • Remove the three 7mm Phillips #1 screws from the button board.
    • Remove the button board from the plastic top.
    • When taken apart the plastic buttons can fall out.
  5. Logitech Extreme 3D Pro Top button circuit board Replacement: paso 5, imagen 1 de 2 Logitech Extreme 3D Pro Top button circuit board Replacement: paso 5, imagen 2 de 2
    • Disconnect the cable from the button board.
  6. Logitech Extreme 3D Pro Top button circuit board Replacement: paso 6, imagen 1 de 2 Logitech Extreme 3D Pro Top button circuit board Replacement: paso 6, imagen 2 de 2
    • Disconnect the smaller cable from the button board.
Conclusión
4 personas más completaron esta guía.
Emanuel Canela
Miembro Desde 01/25/18
1,369 Reputación
7 Guías creadas
Equipo
USF Tampa, Team S7-G1, Passmore Spring 2018 Miembro de USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
Miembros de 4
7 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 2,629
