Introducción
When moving the joystick, the main spring bends. The spring also keeps the joystick upright. After time, the spring can cause the joystick to sag when not in use. In this situation, replacing the spring will be necessary.
Qué necesitas
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
5 personas más completaron esta guía.
6 comentarios
um, what kind of spring is that and where/how would I get a replacement?
same question here
Where can I find a replacement spring?
You can cut the top 360 degrees off the spring with a Dremel cutoff tool, that reduces the work require to operate the stick by about half.
