Introducción
After a long use the joystick trigger might experience a lack of strength within the trigger's internal spring.
Partes
No se requieren partes.
  1. Remove these three Phillips #1 screws:
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Pull apart the joystick chassis by hand. Release this clip located underneath the  hand rest
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  5. Remove the plastic trigger from the joystick.
    • Remove the plastic trigger from the joystick.
Conclusión
Emanuel Canela
Miembro Desde 25/01/18
800 Reputación
7 Guías creadas
Equipo
USF Tampa, Team S7-G1, Passmore Spring 2018 Miembro de USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Miembros
7 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 5
Últimos 30 Días: 23
Todo El Tiempo: 156
