Saltar al contenido principal
Logitech Dual Action disassembly
Qué necesitas
  1. Logitech Dual Action disassembly, Taking out the screws: paso 1, imagen 1 de 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
  2. Logitech Dual Action disassembly, Opening the controller: paso 2, imagen 1 de 3 Logitech Dual Action disassembly, Opening the controller: paso 2, imagen 2 de 3 Logitech Dual Action disassembly, Opening the controller: paso 2, imagen 3 de 3
    • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
    • Separate the top and bottom casing.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
  3. Logitech Dual Action disassembly, Cleaning the buttons: paso 3, imagen 1 de 1
    • Turn the top casing of the controller over to remove all the buttons.
    • Wipe each individual button with a piece of cloth and rubbing alcohol.
Linea de Meta
10 personas más completaron esta guía.
Brian Neuman
Miembro Desde 01/20/15
893 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 7-4, Remmell Winter 2015 Miembro de USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Miembros
3 Guías creadas
Un comentario
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 92
Todo El Tiempo: 6,185
