Saltar al contenido principal
Logitech Dual Action Triggers Repair
Qué necesitas
  1. Logitech Dual Action Triggers Repair, Logitech Dual Action Triggers Repair: paso 1, imagen 1 de 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in red.
  2. Logitech Dual Action Triggers Repair: paso 2, imagen 1 de 2 Logitech Dual Action Triggers Repair: paso 2, imagen 2 de 2
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
  3. Logitech Dual Action Triggers Repair: paso 3, imagen 1 de 1
    • There should be 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 oval shaped buttons.
  4. Logitech Dual Action Triggers Repair: paso 4, imagen 1 de 3 Logitech Dual Action Triggers Repair: paso 4, imagen 2 de 3 Logitech Dual Action Triggers Repair: paso 4, imagen 3 de 3
    • In the center of the controller, pull upwards on the USB cord.
    • Be careful not to pull hard enough to yank the wires connecting to the logic board.
    • With the wire out of the way, remove the screw it exposed. This will disconnect the logic board from the controller.
  5. Logitech Dual Action Triggers Repair: paso 5, imagen 1 de 3 Logitech Dual Action Triggers Repair: paso 5, imagen 2 de 3 Logitech Dual Action Triggers Repair: paso 5, imagen 3 de 3
    • To remove the triggers, push upwards from the back on them.
    • Once far enough, detach the logic board from the back cover piece and the triggers.
  6. Logitech Dual Action Triggers Repair: paso 6, imagen 1 de 2 Logitech Dual Action Triggers Repair: paso 6, imagen 2 de 2
    • If the wire is unplugged solely from the logic board, you can fasten it back into its place.
    • Look at the second picture to see where the wires go.
  7. Logitech Dual Action Triggers Repair: paso 7, imagen 1 de 3 Logitech Dual Action Triggers Repair: paso 7, imagen 2 de 3 Logitech Dual Action Triggers Repair: paso 7, imagen 3 de 3
    • Unscrew the screw on the trigger to remove the back cover.
    • Once removed, carefully pull the back cover off.
  8. Logitech Dual Action Triggers Repair: paso 8, imagen 1 de 1
    • The 3 wires are soldered into the 3 spots circled on the picture.
    • You can now fasten the wire into the right spot on the trigger piece.
Conclusión
4 personas más completaron esta guía.
Brian Neuman
Miembro Desde 01/20/15
893 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 7-4, Remmell Winter 2015 Miembro de USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Miembros
3 Guías creadas
2 comentarios
Hi dear, can you say me the order of colours in the USB cable? I think green, white, red, black thin and black thick. Is It correct?
Cas - Contestar
Where can I get conductive pads for this?
Ginga - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 122
Todo El Tiempo: 8,949
