Saltar al contenido principal
Logitech Circle Speaker Replacement
Qué necesitas
  1. Logitech Circle Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Logitech Circle Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Wedge the plastic opening tool under the black circle lens to gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Speaker Replacement: paso 3, imagen 1 de 2 Logitech Circle Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Speaker Replacement: paso 4, imagen 1 de 2 Logitech Circle Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Speaker Replacement: paso 5, imagen 1 de 2 Logitech Circle Speaker Replacement: paso 5, imagen 2 de 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Speaker Replacement: paso 6, imagen 1 de 2 Logitech Circle Speaker Replacement: paso 6, imagen 2 de 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Speaker Replacement: paso 7, imagen 1 de 1
    • Locate the speaker attachment, and carefully remove the speaker plug from the lens.
  8. Logitech Circle Speaker Replacement: paso 8, imagen 1 de 1
    • Remove the speaker using a plastic opening tool. The battery is attached with glue, so use gentle prying motions to remove speaker.
Conclusión
Emma Cochran
Miembro Desde 09/28/17
110 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 394
