Qué necesitas
Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
The tray should then pop open.
Pull out the tray so that it is fully extended.
Push the left tab in and slide the tray out on the left side.
Pull the gray plastic casing on the right side away from the tray.
Slide the right side of the tray out.
3 personas más completaron esta guía.
