Saltar al contenido principal
Lite-On iHAS324 Chassis Replacement
Qué necesitas
  1. Lite-On iHAS324 Chassis Replacement, Chassis: paso 1, imagen 1 de 2 Lite-On iHAS324 Chassis Replacement, Chassis: paso 1, imagen 2 de 2
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Chassis Replacement: paso 2, imagen 1 de 3 Lite-On iHAS324 Chassis Replacement: paso 2, imagen 2 de 3 Lite-On iHAS324 Chassis Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Chassis Replacement: paso 3, imagen 1 de 1
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Chassis Replacement: paso 4, imagen 1 de 1
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Chassis Replacement: paso 5, imagen 1 de 1
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Chassis Replacement: paso 6, imagen 1 de 1
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
Conclusión
2 personas más completaron esta guía.
Kayla Culpepper
Miembro Desde 03/22/15
675 Reputación
5 Guías creadas
Equipo
Baylor, Team 5-9, Williams Spring 2015 Miembro de Baylor, Team 5-9, Williams Spring 2015
BU-WILLIAMS-S15S5G9
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 23
Todo El Tiempo: 1,301
