Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If the faceplate has become broken or cracked, you may want to replace it.
Partes
No se especificaron partes.
  1. Insert an open paper clip into small hole on left side of faceplate. The tray should click open, use your hands to gently extend it fully.
    • Insert an open paper clip into small hole on left side of faceplate.
    • The tray should click open, use your hands to gently extend it fully.
  2. Push in black tabs on left, right and bottom of outer chassis to unhook faceplate. Push in black tabs on left, right and bottom of outer chassis to unhook faceplate. Push in black tabs on left, right and bottom of outer chassis to unhook faceplate.
    • Push in black tabs on left, right and bottom of outer chassis to unhook faceplate.
  3. Pull face plate away from main chassis.
    • Pull face plate away from main chassis.
  4. Locate the two tabs on the underside of the tray cover. Pry the tabs loose and remove cover. Pry the tabs loose and remove cover.
    • Locate the two tabs on the underside of the tray cover.
    • Pry the tabs loose and remove cover.
  5. Remove and replace faceplate.
    • Remove and replace faceplate.
Conclusión
aaa
Miembro Desde 20/10/11
171 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 1,987
