Saltar al contenido principal
Lite-On LightScribe SHM-165H6S Drive Belt Replacement
Qué necesitas
  1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: paso 1, imagen 1 de 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: paso 1, imagen 2 de 2
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: paso 2, imagen 1 de 3 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: paso 2, imagen 2 de 3 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: paso 2, imagen 3 de 3
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: paso 3, imagen 1 de 1
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: paso 4, imagen 1 de 1
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: paso 5, imagen 1 de 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: paso 5, imagen 2 de 2
    • Lift the top and bottom chassis straight up in order to remove them.
  6. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: paso 6, imagen 1 de 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: paso 6, imagen 2 de 2
    • Extend the tray so that the belt is accessible.
    • Remove the old belt using tweezers.
  7. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: paso 7, imagen 1 de 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: paso 7, imagen 2 de 2
    • Carefully replace with the new belt by wrapping it around the larger gear first, followed by the smaller gear.
Conclusión
5 personas más completaron esta guía.
James Biggs
Miembro Desde 10/12/11
596 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-5, Regan Fall 2011 Miembro de Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Miembros
6 Guías creadas
Un comentario
In case anyone is interested, I used a 11/16” OD x 9/16” I.D. x 1/16” wall, for this exact drive (was a tight fit) and seems to work perfect.
I was so tired of replacing rubber bands every few months!
And yes this is an “O-ring”  it should be less than a buck five eighty at your local big box hardware store.
Jim Mccalb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 21
Todo El Tiempo: 6,536
