Saltar al contenido principal
Lite-On LightScribe SHM-165H6S Disc Tray Replacement
Qué necesitas
  1. Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Chassis: paso 1, imagen 1 de 2 Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Chassis: paso 1, imagen 2 de 2
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 2, imagen 1 de 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 2, imagen 2 de 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 2, imagen 3 de 3
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 3, imagen 1 de 1
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 4, imagen 1 de 1
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 5, imagen 1 de 2 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 5, imagen 2 de 2
    • Lift the top and bottom chassis straight up in order to remove them.
  6. Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Disc Tray: paso 6, imagen 1 de 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Disc Tray: paso 6, imagen 2 de 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Disc Tray: paso 6, imagen 3 de 3
    • Extend the tray fully.
    • Push the tab on the right side to the left.
    • Push the tab on the left side to the left.
    • Remove the tray carefully.
  7. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 7, imagen 1 de 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 7, imagen 2 de 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: paso 7, imagen 3 de 3
    • Guide the replacement tray under the beige tabs.
    • Make sure the grey piece is slid to the right, so the grey nob is under the right-hand groove of the tray.
    • Check to see that the tray extends and closes smoothly.
Conclusión
Una persona más ha completado esta guía.
James Biggs
Miembro Desde 10/12/11
596 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-5, Regan Fall 2011 Miembro de Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 4,118
