Introducción
Is your disco ball not giving off the right groovy colors that it once did? This guide will teach you how to replace the colored panels so you can get back to partying!
Qué necesitas
Turn the device over, so that the base is on top.
Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches.
Insert a new color panel by pushing it into place while lining up the tabs with the notches.
Casi Terminas!
Conclusión
