Saltar al contenido principal
Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement
Qué necesitas
  1. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: paso 1, imagen 1 de 1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: paso 2, imagen 1 de 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: paso 2, imagen 2 de 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: paso 2, imagen 3 de 3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: paso 3, imagen 1 de 1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: paso 4, imagen 1 de 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: paso 4, imagen 2 de 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: paso 4, imagen 3 de 3
    • Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches.
    • Insert a new color panel by pushing it into place while lining up the tabs with the notches.
Conclusión
Equipo
Cal Poly, Team 17-3, Forte Winter 2014 Miembro de Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 9
Todo El Tiempo: 642
