Saltar al contenido principal
Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal
Qué necesitas
  1. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal, Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: paso 1, imagen 1 de 1
    • Turn the device over so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: paso 2, imagen 1 de 1
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: paso 3, imagen 1 de 2 Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: paso 3, imagen 2 de 2
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
Conclusión
Equipo
Cal Poly, Team 17-3, Forte Winter 2014 Miembro de Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 10
Todo El Tiempo: 558
