Qué necesitas
In Terminal type: sudo apt-get install screen
sudo screen /dev/ttyUSB0 9600
Press ⌃A ⇧ : (at the same time). Once you see a : prompt at the bottom of the screen type
exec ::: /sbin/agetty -L -n 9600 ttyUSB0 vt100
Press return a few times on the Lisa keyboard and the login prompt should appear.
Type: ls /dev/cu.*
Copy the result that mentions USB
Then type the following replacing serial with the previous result: screen /dev/serial 9600
Press ⌃A ⇧:
When the : prompt appears type
exec ::: /usr/libexec/getty std.9600
Open LisaTerminal and set the settings to baud rate 9600 and set serial port to A.
Plug the serial cable into serial port A.
In MacWorks Plus and Macintosh System 6, the application Mac240 supports graphics and is generally fantastic for this type of connection.
Mac240 can be acquired from Macintosh Garden.
This was done so I could use mutt for email and w3m for web browsing
mpg123 is great for music if your connected computer has speakers.
