Saltar al contenido principal
Linsay Model F-7HD2CORE Screen Replacement
Qué necesitas
  1. Linsay Model F-7HD2CORE Screen Replacement, Screen: paso 1, imagen 1 de 3 Linsay Model F-7HD2CORE Screen Replacement, Screen: paso 1, imagen 2 de 3 Linsay Model F-7HD2CORE Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Insert your plastic opening tool in between the black and white portions of your device.
    • Gently pry the top screen from the base of the tablet.
    • Your tablet should now look like the third photo.
  2. Linsay Model F-7HD2CORE Screen Replacement: paso 2, imagen 1 de 2 Linsay Model F-7HD2CORE Screen Replacement: paso 2, imagen 2 de 2
    • Peel the microphone from the back of the device.
  3. Linsay Model F-7HD2CORE Screen Replacement: paso 3, imagen 1 de 1
    • Remove the tape from the indicated copper strip.
  4. Linsay Model F-7HD2CORE Screen Replacement: paso 4, imagen 1 de 2 Linsay Model F-7HD2CORE Screen Replacement: paso 4, imagen 2 de 2
    • Use your 00 phillips head screwdriver to remove the three 4mm phillips screws circled in red.
  5. Linsay Model F-7HD2CORE Screen Replacement: paso 5, imagen 1 de 1
    • Remove the soldered portion of the circuit board on the screen.
    • You will need a soldering kit to reattach this part.
  6. Linsay Model F-7HD2CORE Screen Replacement: paso 6, imagen 1 de 2 Linsay Model F-7HD2CORE Screen Replacement: paso 6, imagen 2 de 2
    • Use the blunt end of the spudger to remove the circuit panel and battery from the glass screen portion of the device.
    • There will be several small hooks holding the screen onto the back panel.
  7. Linsay Model F-7HD2CORE Screen Replacement: paso 7, imagen 1 de 2 Linsay Model F-7HD2CORE Screen Replacement: paso 7, imagen 2 de 2
    • Gently pull the two pieces of the tablet apart.
    • Your tablet should now look like image two.
    • You are now ready to attach your new screen!
Conclusión
2 personas más completaron esta guía.
Equipo
Penn State, Team 1-5, Kaschak Winter 2015 Miembro de Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Miembros
2 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 1,318
