Saltar al contenido principal
Linsay Model F-7HD2CORE Battery Replacement
Qué necesitas
  1. Linsay Model F-7HD2CORE Battery Replacement, Battery: paso 1, imagen 1 de 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: paso 1, imagen 2 de 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Carefully insert your plastic opening tool in between the white and black sections of your device.
    • Gently pry the top screen portion from the base of the tablet.
    • Your tablet should now look like the third image.
  2. Linsay Model F-7HD2CORE Battery Replacement: paso 2, imagen 1 de 2 Linsay Model F-7HD2CORE Battery Replacement: paso 2, imagen 2 de 2
    • To completely remove the base from the top of the tablet, peel the microphone from the back.
  3. Linsay Model F-7HD2CORE Battery Replacement: paso 3, imagen 1 de 2 Linsay Model F-7HD2CORE Battery Replacement: paso 3, imagen 2 de 2
    • Remove the two pieces of tape holding the battery in place by gently peeling it off.
  4. Linsay Model F-7HD2CORE Battery Replacement: paso 4, imagen 1 de 1
    • Using the spudger, carefully peel the battery off of the tablet panel.
    • Tape of the back of the battery will be very strong, pull gently!
    • The metal exterior of the battery can be quite pliable. Use caution when removing the battery from the tablet.
  5. Linsay Model F-7HD2CORE Battery Replacement: paso 5, imagen 1 de 1
    • To remove the battery, completely desolder the wires connected to the circuit board.
    • To reattach the new battery, you must solder the wires back on.
Conclusión
2 personas más completaron esta guía.
Equipo
Penn State, Team 1-5, Kaschak Winter 2015 Miembro de Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,443
