Saltar al contenido principal
Linksys WRT54GS v2 Rear Case Replacement
Qué necesitas
  1. Linksys WRT54GS v2 Rear Case Replacement, Front Case: paso 1, imagen 1 de 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Rear Case Replacement: paso 2, imagen 1 de 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Rear Case Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Rear Case Replacement: paso 4, imagen 1 de 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Rear Case Replacement, Motherboard: paso 5, imagen 1 de 1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Rear Case Replacement: paso 6, imagen 1 de 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Linksys WRT54GS v2 Rear Case Replacement, Rear Case: paso 7, imagen 1 de 1
    • Removing the router's rear case is the same as removing the motherboard, since the two parts are attached to each other.
    • Once you complete this step, your router will be completely disassembled.
Conclusión
Allian Roman
Miembro Desde 10/12/11
276 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-4, Regan Fall 2011 Miembro de Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,465
